2010 camaro build suggestions.
Old 12-08-2009, 12:49 AM
boostedyards86's Avatar
Default 2010 camaro build suggestions.
I currently have a ls3 manual camaro. It has stock motor with a tvs2300 pushing 6.5# through ARH LT. Full 4in intake, methanol injection and a texas speed cam that I will post up the specs for it in the am. I was gonna do little things to it from here, but we blew out the trans and have decided since that will be built lets try to do some other crazy stuff.
anybody know what can be expected from a 2300tvs or a a decent sized twinscrew? i love the punch that pd blowers have, but since the motor is getting forged i want to know if these types of blowers will have the grunt to make it worth while. If not i'm looking into some precision turbos for a nice lil TT build.
my other question would be the engine build. I'm thinking an LSX block with ls7 ported heads. now bore and stroke i'm not sold on yet. I would like the engine to rev to 7k-7.5k... Suggestions would be great. I'm still learning engine building in big bad V8 world.
Old 12-08-2009, 06:01 AM
old motorhead's Avatar
I have a TVS2300 in a manual tranny LS3 vette. With blower cam, all the bolt ons, no cats, and straight through mufflers, it puts down 672 at the wheels. That's with a 2.9" drive pulley making 8.5psi. I don't know where you get into belt slip boost wise, but I don't think it's much over where I am now. You might get 10psi with the stock pulley system. I thought of going to a smaller pulley for a little more, but I haven't harnessed what I have now.
There's a guy over on the vette forum that forged his LS3 and is well over 800 rwhp with the TVS2300. He's had to do quite a bit of work on the blower drive system to prevent belt slip (both front and back end). I think he's at 14 or 15 psi. Also, I think he's had to completely rework his fuel system. When you're at those power levels, it's a whole nother ballgame.
Old 12-08-2009, 05:19 PM
i'm running a 3.6" pulley and am seeing 6psi...and i have the same mods as you. did you port the heads or do any other motors work?
Also any other ideas people?
Old 12-08-2009, 06:16 PM
Stock heads here. LS3 heads are pretty good as is. I'm not going to do any other motor work unless the motor scatters. Hopefully not for a while.
What are your power goals? I wouldn't fool with a stroker motor unless you're wanting 1000+. Your stock heads are good too. If you're wanting big power, I'd upgrade the pistons and rods, leave the crank as is, and blow 15 or 20 psi through it.
Old 12-09-2009, 04:58 AM
EPP
EPP's Avatar
Take a look at the 2300 on this Hummer H2 we built. http://www.exoticperformanceplus.com...Car.php?car=56
It has a jackshaft running to the rear where there is a cog drive set-up. This allows the blower to make a lot more boost. We saw 15 psi of boost with a 3.0 pulley on the front of the blower. We're now at 11.5 psi of boost with a larger 3.2 pulley on the head unit. Bob
Old 12-09-2009, 12:34 PM
venom ws7's Avatar
The 2010 is already heavy SOB dont go with LSX Block unless your looking for 1000+rwhp build.
how much power are you looking for??
I say since you already have LS3 then get a good rotating assembely and go 418ci or maybe even 427ci if your not planning to run high boost.
and add a D1SC or TVS With good blower cam and boltons IMO you'll reach 750+rwhp on pump gas and 13-15psi....
Good luck
Old 12-10-2009, 10:09 AM
we are looking for low 9's so 1000rwhp wouldn't be to far off from what we are looking for. Thats why we are considering ditching the TVS.
Old 12-10-2009, 10:11 AM
and we already have a decent cam for the car. 229/236 114lsa +4 advance 6xxlift intake 6xxlift exhaust...can't remember all the numbers.
Old 12-10-2009, 10:39 AM
EPP
EPP's Avatar
A ProCharger Cog Race Kit designed for the 2010 Camaro SS with an F-1A head unit would get you the low 9's. A built LS3 engine with AFR 225 heads, along with a FAST 92mm intake for the cathedral ports would handle 20 psi of boost.
The above engine is an LS2/402 with off the shelf AFR 225 heads, and the FAST 92 intake along with an F-1A ProCharger. It is in a CTS-V with an IRS rear with a 9 inch center section. We're only currently at 12.5 psi of boost, it has plenty of room to grow. Bob
Old 12-10-2009, 10:52 AM
venom ws7's Avatar
If your looking for low9s and 1000rwhp then I agree with Bob built 418ci LS3 with F1A
but you need some weight reduction or more than 900rwhp to run low 9s with 3900+lbs car..
Quick Reply: 2010 camaro build suggestions.
