Rear Mount Cams?
Old 12-08-2009, 06:09 PM
chase3's Avatar
Question Rear Mount Cams?
I currently have a 232/234 112lsa cam. Didnt get to run it very long due to burning holes in 3 of my pistons thanks to LMR. Anyways while i have the motor out i want to put an appropriate turbo cam in it and was wandering what you guys thought..THANKS Chase
Old 12-08-2009, 07:18 PM
OUTLAWZ RACING's Avatar
What size turbo and motor and hp goals?
Old 12-08-2009, 07:41 PM
chase3's Avatar
76mm hoping around 700rwhp around 10 psi
Old 12-08-2009, 07:45 PM
Take a look at the epp blower cam, or thunder racing turbo cams. Va speed can also spec you one. So your keeping the 347? If so any one of these guys can get you there on that set up.
I ran the epp blower cam in a 4xx vic jr patriot stg3 heads on a six speed. The highest I see was 813 710 on 17-18 psi mustang dyno on a 76mm gts
Old 12-08-2009, 07:52 PM
chase3's Avatar
yeah i hear people talking about the epp cam,,but i thought alot of people were saying to do reverse split with rearmounts..and yes as of now staying 347..though a 383 might be what i end up doing with an lq4 block
Old 12-08-2009, 07:59 PM
If your crank is in order take that lq4 and drop your crank in it and throw in pistons and rods and you have a 370 ci for next to nothing. I tried the reverse spit befor and I dident like it. I sold it to a member here and he did dam good with it. I dident like the power band it peek way to early for me. turbos love rpm. But I like the epp cam easy on the springs and it sounds and performs good imho.
Old 12-08-2009, 08:07 PM
chase3's Avatar
im with you on the not wanting it to peak to early..is the epp cam the one that you run?? I definetly want it to sound rough and would like to be full bost in the 3k's
Quick Reply: Rear Mount Cams?
