What kind of timing are you guys running on your F/I setups???
I'm currently at 14deg of timing on my forged 347/F1C setup (18# of boost). Just looking to see where the rest of you guys are at timing wise on your tune.
Thanks,
Thanks,
8 sec potential, 12 sec slip
I am at 20° on pump gas only right now (I have alkycontrol kit, but not using it right now because it is already running pig rich on 91 octane alone). Forged 9.2:1 370/ F1 at about 12-13psi.. ~700rwhp and still working out the bugs.
15 @ 15.5psi, 8.8:1 COMP on pump gas. Just make sure you have your tune setup to pull a bunch of timing if your iats go past about 145ish. I blew a forged motor that way. 180 iats on pump gas is not your pistons friend.
i think i was around 12 lbs boost, IAT's a little over 100 degs, 93 octane with a splash of 110, 22 degs put the timing mark right at the curve on the plug,
i think the AFR's were around high 11's, low 12's, but i run a carb, so prob a little better cooling in the engine-i start at 30 degs, ramp up a little higher in cruise mod, then drop timing as the boost goes up-i think my comp is around
9.2
9.2
Update to my input.
Just turned the timing down to 15.5* on the Procharged car during a dyno session this morning. 10 psi on a stock longblock. Making absolutely sure we stay out of detonation. 542 RWHP/488 RWTQ SAE. OUT OF INJECTOR from 5300 on up. 42#'s are coming out, starting to shop for some 60#'s.
Also looked at the tune on the Vortech car. We had turned it down to 16*.
Yeah, I think the OP knows that he has to carefully tune his own car and that what we run on our cars is just interesting reading rather than accurate guidance for his setup - which can be greatly different from other posters in this thread.
12* of timing, 15lbs, 9.7:1. 91pump and 50/50 meth, 364c.i., afr's 11.0-11.7. I feel like I have alot of power left of the table via timing as well. I like "safe" though
a good reference for anything over 20lbs without an air to water cooler even with race gas is 16* total timing
unless you datalog everything and you know what your engine is exactly doing and what your IAT are as stated above you don't want to push it
it also makes a huge difference in you combustion chamber design as to your cylinder temps
but at 16 * the odds of rattling it are very very low if your running good gas
pump gas 15 #s of boost and 16* total timing is pretty safe as long as your IAT's are decent
