hinson c5 turbo kit
hinson c5 turbo kit
Just started installing my turbo kit and having problems with the down pipe hitting the coil packs is there a differance between z06 coil packs and a c5?
i have seen the cast manifolds tti uses in person and they look very sturdy, it is just too bad they do not make those for the f body. anybody know if they will fit on an f body ?
LS1 Coil - Flip it upside down so the outlet of the coil is pointed up and use a longer plug wire to reach the spark plug.
Truck/LS7 Coil - Remove the front bolt, clock the coil up. The left bolt will hold in place fine. Factory wire length will work.
