Help please jgs 60mm wastegate
Old 12-15-2009, 12:18 PM
Kwt_DragerZ's Avatar
Exclamation Help please jgs 60mm wastegate
Hi all ,,
today i will install my Custom KYTP s91 turbo kit . it came with jgs 60mm wastegate .
now i want to know when the standard spring start at what PSI ? Also , i have to other springs so wich one i have to you ?
please help me and if anyone have there application tell me.
Replay me as soon as you can guys , Thanks
Old 12-15-2009, 01:00 PM
LS1TECH Sponsor
DrTurbo's Avatar
Start with the default spring. Its 7psi I believe......and with a boost controller you should be able to get 15-16psi.
Old 12-16-2009, 03:24 AM
Thanks DrTurbo.
and can you tell me the other springs start ??
Old 12-16-2009, 07:51 AM
Restricted User
98Z28CobraKiller's Avatar
Originally Posted by Kwt_DragerZ
Thanks DrTurbo.
Don't worry about the other springs. All you need is an AMS controller and CO2 to get whatever boost level you want above the spring that you have in there now.
Quick Reply: Help please jgs 60mm wastegate
