Stock bottom ls1, V2 S-trim, expected power?
What kind of power could I expect to run with a vortech v2 s-trim on a stock bottom end ls1, head work, ls6 cam, ls6 intake, full catless exhaust, etc. Also, what would be a recommended safe boost level? It would be through a t-56 and a 12 bolt.
Thanks.
Thanks.
WIth a simple meth injection kit you could ~8-10psi with no intercooler and probably 10-12 with an IC(and the meth). But I would recommend a piston change and rod bolts (at a minimum) before anything more than 8 tuned nice and safe.
In that range I think you would see ~460-510rwhp on 8# no IC, and ~475-520 with a good IC.
Jim
Jim
Jim
Jim
