how to wire procharger fans
Old 12-21-2009, 09:36 PM
pdasterly's Avatar
Default how to wire procharger fans
i have two fans, a 16 zirgo and a 9 spal, how can i wire these to the factory pcm? can i just splice the factory postive and negative fan wiring?
Old 12-23-2009, 09:35 PM
pdasterly's Avatar
anyone?
Old 12-24-2009, 06:39 AM
AFASTYZFR1's Avatar
Mine are wired up just like stock. Just make sure you test the direction on the fans after you hook them up, a lot of times people get them backwards.
Old 12-24-2009, 07:44 PM
pdasterly's Avatar
do your fans run in high speed mode?
Old 12-24-2009, 08:45 PM
airforcemanss's Avatar
to the op, like the post state above, just make sure it's pointed the correct way and hook them up as if they were oem standard. ive asked this question in a pm with a member on this board that has done it on his build. btw, let us know how your iat's are and take pics of the zirgo fan installed so we can see clearances of the setup for members on this board that are going to tackle this down the road.
im going to throw this out there, if anyone has an extra fan shroud or is going to make one, please make a duplicate of the (final copy) ( that has been test fitted and works). Im talking about the 16" hole and the 9" hole in the upper corner where the head unit goes under (and does not touch the 9" fan) its mocked up correctly and works. pm me if you want to work something out. thanks -james
Old 12-24-2009, 08:59 PM
AFASTYZFR1's Avatar
Yep, high and low.......can completely control either one
Old 12-26-2009, 03:50 PM
cals400ex's Avatar
where can you get a factory connector? i have used procharger fans but the connector on the wire is missing.
Old 12-26-2009, 05:20 PM
dschmittie1's Avatar
The procharger fans should just be a weather pack connector. You get get them from places like summit and stuff
Old 12-26-2009, 08:25 PM
pdasterly's Avatar
i have a shop make a shroud, costs about $40 bucks plus the fans. Zirgo zf16 was 75 and spal was 8 inch 80
Quick Reply: how to wire procharger fans
