Should I run dual 38mm or 44mm wastegates.
I had a past thread about what to do for my turbo setup because I like to do drag racing and road racing. Road racing I want to run absolute minimum boost 3.5 psi.
I'm going to do dual wastegates, so running 3.5 psi with a ls2, ported heads, 76mm turbo. Would the Tial 38mm wastegates be enough? Despite the amount of money that I've put into this car, i'm still being a cheap ***.
Oh for what it's worth the waste gates will be positioned 'well' in terms of being on the outer edge of a 90 curve.
I'm no expert, I'm a cabinet guy, but wouldn't it be more than plenty running the 38's. 76mm worth of gate seems to be enormous for anything under 900 rwhp.
CZWA-I'm interested in similar goals, I'm a conversion too, but i'm mounting twins up by the valve covers with the IC on top of the motor for minimal plumbing and instant throttle response. I'll be using the 38's with the 3 lbs spring at first.
I spoke to Louis @ LG about this same thing and he suggested the Tial 38's. 44's would be overkill IMO under 402 ci
Thanks for the opinions, still haven't made up my mind haha.
Here's the merge pipe, i've yet to buy wastegates so progress is waiting on my decision, I have some time to think though cause i'm working on the viper differential going in.
Depending on where you reference your wastegate signal from the boost may end up being higher or lower than that 4.3psi. Reference them right off the turbo and put your boost gauge in to the manifold and you will notice a pressure drop due to your intercooler and piping losses. Should put you in the mid 3psi range.
