white smoke from intake area
Old 12-30-2009, 11:12 AM
pdasterly's Avatar
Default white smoke from intake area
started car this moring and im gettin alot of white smoke from the intake area, looks like the rear of the manifold. I though the smoke would go away but she keeps smoking. what should i check first?
Old 12-30-2009, 12:13 PM
XtremeDime's Avatar
I had this problem on my s10, I had a blown intake manifold gasket that was leaking coolant onto the back of the block and transmission, burning it causing it to smoke.
Old 12-30-2009, 12:16 PM
blk00ss's Avatar
Water doesn't flow through the intakes on LS motors.
Old 12-30-2009, 12:32 PM
XtremeDime's Avatar
I know lol, I was thinking more along the lines of a head gasket leaking on the backside, I just failed to mention that part. I just woke up lol
Old 12-30-2009, 12:52 PM
DeltaT's Avatar
White smoke can also indicate unburnt, vaporized fuel. I would definitely check manifold seating and bolts, as well as uncapped nipples and (hopefully not) cracks.
Jim
Old 12-30-2009, 02:34 PM
pdasterly's Avatar
i bought a vacuum gauge, everything is cool now, thanks. engine holds at 20 psi thru the brake booster
Quick Reply: white smoke from intake area
