Shurflo pump question? Help please
I have the 8000-643-210 pump. Have it connected thru a 30 amp relay. Is this pump a constant running pump or does it cycle on or off? I disconnected the out put and started the car but i didn't get any oil out of that side. I double checked all the wiring and everything is good with 12.5 volts at all connections.
From a 12v switch source to the relay, power for the pump comes from the positive post on the drivers side engine compartment with a 25amp fuse.
I did have a problem when I wired it per the STS instructions, the fuel pump wire from the pcm that they tell you to tap into didn't have enough voltage/amperage to consistantly turn the pump on.
You did check the arrow on the pump to make sure it's flowing in the right direction?
