twint turbo with truck manifolds
Old 01-08-2010, 11:32 PM
elias_799's Avatar
Default twint turbo with truck manifolds
can i get some pictures of how you guys do it.
from what i can see you need to relocate the battery, coolant reservoir and the fuse box, am i missing anything else ?
do i need to stand up the rad ?
i have a bmr turbo k member btw
Old 01-08-2010, 11:56 PM
reamo04's Avatar
its not 100% necessary to move the battery and coolant resevoir.
look here, placement can be the same
http://lt1boost.net/twin_turbo_kit
Old 01-09-2010, 05:46 AM
elias_799's Avatar
^^ that looks good, but it will require standing up the rad, and i really do not want to do that.
Old 01-09-2010, 09:54 AM
Josh@KY-Turbo's Avatar
Forget twins with 6.0L mainfolds then.
Old 01-09-2010, 03:34 PM
ninetres's Avatar
Why the heck not? Its not really a big deal????
Old 01-09-2010, 03:50 PM
1fast bird's Avatar
Moving the radiator up and vertical opens up a ton of room and options.
Old 01-09-2010, 03:58 PM
HUNTER02SS's Avatar
Here is a pic of my old TT Manifold setup.
http://s216.photobucket.com/albums/c...rbopics001.jpg
Old 01-09-2010, 07:00 PM
reamo04's Avatar
standing the radiator vertical is one of the best things i ever did.
Old 01-09-2010, 07:21 PM
Tzion_ben_Arthur's Avatar
Agree... A little work, but very much worth it.
Old 01-09-2010, 11:57 PM
elias_799's Avatar
how much cooling efficiency am i going to loose by standing up the rad ?
if i stand up the rad i do not need to relocate the battery or the fuse box to fit the twins ?
Old 01-10-2010, 03:25 AM
reamo04's Avatar
correct, and run a griffin my car runs cooler than factory
Old 01-10-2010, 03:48 AM
ninetres's Avatar
None.
Old 01-10-2010, 08:05 AM
MUSTANGBRKR02's Avatar
If you had vbands on the manifolds could you flip them upside down?
Old 01-10-2010, 10:39 AM
See why we stand the radiator up now? No need to relocate the fuse blocks or batteries.
Old 01-10-2010, 10:42 AM
elias_799's Avatar
^^^^ yes, thanks josh, what are you going to for air filter on that set up ?
also what turbo's are those if you do not mind me asking.
Old 01-10-2010, 10:59 AM
Those are pics of an old build. We were moving the battery to the trunk on that build. Plan was to use small mushroom type filters. The turbos are TO4E 58mm units.
Old 01-10-2010, 11:13 AM
elias_799's Avatar
do you need to use pusher fans with the turbocharges in that place ?
if you do which ones would be best
Old 01-10-2010, 04:46 PM
elias_799's Avatar
hunter how do yo keep the hood closed ?
Old 01-10-2010, 05:21 PM
HUNTER02SS's Avatar
Hood pins. With a white car they are not very noticable.
Old 01-10-2010, 08:03 PM
Classic's Avatar
Here is a picture of my twin setup with truck manifolds. Although the radiator is not upright (factory size w/ factory fans) the crossbar has been cut and the radiator/fan setup was pushed forward. The battery and fuse box have also been relocated as you can see.
Quick Reply: twint turbo with truck manifolds
