water/meth kit for centrifugal setup
Hi was hoping someone may be able to help me in regards to meth/water injection. I was looking at buying a setup for my car here in australia but wanted to check about dangers of it and if it would be an advantage for me. I run a 383 ls1 with a centrifugal blower at 15lb and 8.5 cr and a fmic. It currently is about 670rwhp but am about to change cams. I live in the tropics so my IT is normally 89 degrees or so on dyno runs with AT about 2-4 degrees lower on average.
Any suggestions on which kit to use would be appreciated.
Are you going with more boost? With 15psi and 8.5cr you shouldn't need it. Unless you just want the cooling properties of it. Most people here use it as a fueling crutch so they can run more boost than pump gas allows. With 8.5 compression I think you could probably even increase it to 18-20psi safely. Plus don't you guys have higher octane pump gas than the US?
Sounds like i should be able to push a bit more boost in safely. I did some numbers and should be able to run 2 less teeth on the blower cog and keep the impeler speed within the recomended maximums.
Best car has made is 704rwhp but i am about to put in a new lsr centrifugal cam and also swap the engine with my other car which has its driveline set up a bit better for running down the quarter. So just looking to squeeze as much out as i can fairly safely.
