Picked up LS9 Head Gaskets - Pics and info inside
So I just picked up some LS9 gaskets, and there seems to be a lot of confusion on the exact specs.
im not sure if this is the correct way to check thickness on the gasket, but squeezing the dial calipers a little bit showed 0.052 - 0.053 ish thickness, depending on how hard i squeezed, and 0.048 right next to the rivet.
bore size is 4.100
7 layers, 4 "active" and 3 "inactive layers"
these fit on my 4.010 bore, and went over my ARP studs just fine. the gasket fit PERFECTLY around the dowels with no extra play.
if anyone needs more info, let me know
bore size is 4.100
I just ordered them from my local dealership, tustin chevrolet. obviously they were a special order and came straight from detriot
im an ex GM technician, so i get a good deal on parts, but i paid $80 for the set. id guess you'd spend about $100-120 ish at full price, but who knows, call up a dealer and see what they quote you...
the difference is:
stock 6.0 gasket is a 3 layer,
escalade 6.2 gaskets are a 5 layer,
LS9 (ZR1 corvette) are a 7 layer.
what i like the most is that GM Performance Parts lists them for "forced induction applications" if you look up any other gasket, it says "for naturally aspirated engines only"
Can anybody confirm that the LS9 and LSA use the same head gasket part number? or does the CTS-V use a different gasket. If they are different part numbers their may be another option while the LS9 are out of stock
well, just an FYI, but there are alot of cadillac dealers with these in stock for the CTS-V. I just called up a dealer and they directed me to a dealer about 40 minutes away with a set in stock. Ill be grabbing them tonight
