Boost/Power increase from pulley change? D1sc 346 ci
Old 01-14-2010, 01:07 AM
8 Second Truck Club
Blown06's Avatar
Default Boost/Power increase from pulley change? D1sc 346 ci
Heres the current setup:
346/D1sc
54375 impeller speed at shift point (about 87% of max)
creeps up to 15 psi at shift point (just barely hits 15)
If I change to a pulley combo to max out the D1 at 62000 impeller speed, how much boost should I expect to gain?
I have no idea what kind of rwhp it makes right now, but it traps 126 mph in a 4550 lb. truck. I'm guessing somewhere between 600 and 650 rwhp. Do y'all think it would be possible to hit 130 mph or more with this pulley change?
Other details in sig.
Old 01-14-2010, 11:43 AM
Rickys S/C Z28's Avatar
i dont know but im doing the same thing this year right now im running a 7.25 crank and a 3.7 headunit but im going with a 3.4 headunit this year that SHOULD be max rpm and im hoping to see some were around 17-18 psi but but i would rather see 700RWHP i dont care about boost numbers LOL
Old 01-14-2010, 11:12 PM
blue00ZZleeper's Avatar
No it wont be maxed out. 7.65 w/ 3.4 blower at 6700ish rpm is max. Always remeber you can go up in crank pully to make more boost and retain decent belt wrap.
Old 01-15-2010, 12:27 AM
8 Second Truck Club
Blown06's Avatar
My current pulley combo is 7.4" crank, 3.85" blower shifting at 6900 (6-rib).
My new pulley combo is 8" crank, 3.65" blower shifting at 6900 (8-rib).
Old 01-15-2010, 12:42 AM
im not sure on how to do the math but from what i have seen a 7.25 crank and a 3.40 head unit spinning to 6800 should be 64k right?
Old 01-15-2010, 02:00 AM
I_Need_Land's Avatar
7.65/3.4 @ 6800 = max
Old 01-15-2010, 09:33 AM
AFASTYZFR1's Avatar
7.25/ 3.4 @ 6800 = 59450
max is 62000 on a D1SC and 65000 on P1SC, its close
Pm me your email and I can send you the calculator, or you can find it on the forum.
Old 01-15-2010, 10:37 AM
thanks man!!
Old 01-15-2010, 11:24 AM
viper9403's Avatar
Should make around 18#, blower will eventually run out of cfm.
Old 01-20-2010, 06:38 PM
thevho's Avatar
whats the smallest pulley u can go on the D1 ...?? and were do you get them at..?? what about the crank...??
Old 01-20-2010, 08:20 PM
8 Second Truck Club
Blown06's Avatar
Pulley size isn't really the question you should be asking as you could in theory put any pulley you want on it. Procharger doesn't recommend spinning this blower too far past 62000 rpm. So if you looking for max power you need a pulley combo for your given shift points or max rpm to achieve this impeller speed.
Use this equation to help you out.
(Crank Pulley Dia. x Max RPM x Blower Step Up Ratio)/Blower Pulley Dia.= Impeller RPM
For example a typical maxed out F-body setup would be
Crank Pulley: 7.65"
Blower Pulley: 3.4"
D1sc Step Up: 4.1
Max RPM: 6800
7.65 x 6800 = 52020
52020 x 4.1 = 213282
213282 / 3.4 = 62730 rpm impeller speed
Old 01-22-2010, 03:29 PM
doesn't know what quit means
lablackbeast's Avatar
what set up would yal run so it wont be maxxed out....??
Quick Reply: Boost/Power increase from pulley change? D1sc 346 ci
