Where to get forged 5.3L Pistons
Old 01-19-2010, 06:16 AM
pwrtrip75's Avatar
Default Where to get forged 5.3L Pistons
Does any place make forged 5.3L pistons? (w/o having to custom order) Or does anyone know what a 5.3 block can be safely bored out to? Can you use the 5.7 pistons and not have to worry about too thin of a cylinder wall for 800-900hp at crank?
They dont have to be dished cause the factory one is already low enough compression w/ 317 heads.
Probably the wrong section.... but its for my Turbo build so ?? My car broke and even though its still on the trailer and covered w/ snow im guessing its a rod thats knocking.
Id search the classifieds for pistons but that is so messed up
Old 01-19-2010, 06:24 AM
LS1Tech Sponsor
hellbents10's Avatar
Wiseco makes a set that would work pretty good with your 317 heads. The iron block can go to a 5.7 bore size no problem too.
Old 01-19-2010, 06:33 AM
nastychevelle's Avatar
i say stick with the 5.3 dont bore it out to a 5.7 keep them walls thick and use wiseco forged 5.3 pistons
TSP has them
http://texas-speed.com/shop/item.asp...d=989&catid=38
Quick Reply: Where to get forged 5.3L Pistons
