Help with eboost vac lines
I had to take my turbo exhaust manifold off due to cracking and I replaced it with a new one. When I took the turbo and manifold off I had to remove the vaccum lines that went to the turbo and wastegate. The problem is that there is three vaccum hoses going to the turbo, wastegate and one other spot, (possibly two to the wastegate, I can't think of the location right now) I don't have the paperwork for the boost controller, so I can't figure out the correct location for the vaccum lines. I know there is a splitter for the boost controller, and the three lines come off that and each line is numbered. So if anyone knows which line goes to what part that would be greatly appreciated.
Thanks
Justin
Thanks
Justin
