How will a TC76 perform compared to an MPT70 or MPT76?
Stack a TC78 Aginst the supposed Bad Boy MPT88 ...
Guys on a strict budget, sure go for the Master Power turbos.
Guys that want the most out of thier setups spend the $$$ for a quality unit.
I myself will not put a Master Power turbo on one of my setups.
The turbine wheel is the killer here....purchase a tc76 with a p-trim wheel and see what happens....now order a masterpower 76 with the largest 87mm turbine wheel and see what would happen.
Why even bother with the P-trim wheel. The F1 wheel is a damn near standard option on the TC series of turbos. A MPT76 doesnt hold a candle to the TC76. Period. I have seen the Maps personaly, Hence the reason I wont offer a Master Power anything on my setups.
The TC series have a smaller compressor housing (same size wheels),
make a little less power tham the T series Turbonetics, but spool faster and are much more compact if your pushed for space in the engine bay or under car if rearmount.
Is it a drastic difference in physical size between the TC76 and T76? A friend is giving me a hell of a deal on a Turbonectics T76, only 10hrs of run time, for $750. But if I can save a substantial amount of space I may opt for a TC76, do you guys think the price of that T76 is good?
Coal Mining Director
Interesting thread. Up until now, I've been basing my 5.3 build (I'll figure out the 6.0 later) around a MP76. This thread has me thinking twice. So, given a 5.3 w/ported 6.0 heads, '03 Zo6 cam, 3400 stall, and a target of 15psi....what might be my best choice going with Turbonetics?
Sorry...not meaning to hijack the thread...this just has me curious.
Oh, and I guess I might have a new mp76 for sale
Budget?? LOL Yeah, I WAS on a budget...'till I passed the 23k mark being sucked from my wallet. I originally intended to spend 10-12k, but now realize that I'm into this thing way too much to turn back. Along the way, dependability became very important as I decided this car needs to have daily-driver ability. I had read that many folks here were very happy with MP, so I went with them. Maybe I should have read a little more?
There's nothing wrong with MP turbos, your comparing a $750 turbo against a $1000+ turbo... I haven't heard of any one failing a MP turbo in a LONGGGGG time and there's plenty of them out there. The MP Q-trims are brand new and not a lot of guys running them yet. Since the turbine wheel is only about 2mm smaller then a F-1 Turbonetics wheel (67mm vs 69mm), power should be in the same ball park. I don't think you could tell much of a difference unless you where actually maxing out both units, then the Turbonetcis should be good for a few more HP.
