Procharger torque specs?
Old 01-26-2010, 12:55 PM
ss.slp.ls1's Avatar
Default Procharger torque specs?
I have a DISC head unit off of a Mustang. I also picked up a J-bracket (with the ChevyChad mod). I have to reclock the internal slinger gear and I contacted procharger and found that the slinger bracket torque spec is 20 ft lbs, use red locktite.
I don't know the torque spec for the 1/4x20 housing back plate bolts or the torque spec for the 5/16x18 housing to bracket bolts. (Procharger Tech guy said he didn't have them on hand)
I was wondering if anyone had a list of torque specs?
Old 01-26-2010, 10:21 PM
blue00ZZleeper's Avatar
Not that tight. Their easy to strip out. I go snug and then probably 1-1.5 more full turn.
Old 01-27-2010, 07:00 PM
danbap's Avatar
did you check to make sure the rotation is the right way? i thought all mustangs use standard rotation and the f body's use reverse rotation?
Old 01-27-2010, 07:15 PM
ss.slp.ls1's Avatar
I did check it, its reverse, and according to the clocking sheet copied below, the Mustang it came off of is Reverse as well.
(First letter is the clocking, second letter is the rotation)
P-1SC through F Series Superchargers Supercharger Supercharger
Applications Clocking Rotation
1996-04 4.6L Mustang GT, Bullet, Cobra A R
2003-04 Cobra (6 rib) A R
1994-2008 Mustang 4.0 and 3.8L V6 A R
1997-2009 C6 and C5 Corvette* C R
1998-02 LS1 Camaro-Firebird A R
2004-06 Pontiac GTO / 2008 G8 A S
Carb Chevy Serp/Cog Belt (with elec. or mech. water pump) call call
1997-03 Ford 4.6L, and 5.4L Truck A S
2004-09 Dodge 5.7 Hemi Truck C S
1994-95 Mustang GT, Cobra B S
1993-97 LT1 Camaro-Firebird B S
1999-09 Chevy Truck, SUV B S
2003-08 Hummer H2 B S
1996-01 Dodge 5.9/5.2 Truck, SUV B S
2006-08 Charger HO (5.7 & 6.1) C S
2006-08 Charger / 2006-09 Challenger Stage II (5.7 & 6.1) C R
2008-09 Challenger HO (5.7 & 6.1) C S
2005-08 300/Magnum C S
1996-98 4.6L Serp Race Kit with F1-R C R
1996-98 4.6L Cobra Cog Race Kit C R
1986-93 Mustang Cog Race Kits C R or S
1992-96 LT1 Corvette (and LT4) C R
Carb Chevy Reverse Drive Cog C R
2003-04 Cobra (Cog Drive) C R
2005-09 Mustang 3 Valve C S
1986-93 Mustang 5.0L (with or without AC) C S
1985-91 TPI Corvette C S
1988-92 TPI Camaro-Firebird C S
1988-2000 GM 5.7, 7.4 Truck,SUV C S
2004-06 Ford 5.4L Truck C S
All 12" Supercharger Applications C R or S
* C5 versions prior to April 2005 B R
C - Series Superchargers Supercharger Supercharger
2000-2003 Focus C R
2003-06 Nissan/Infiniti 350Z,G35,Fx35 A R
Old 01-27-2010, 07:18 PM
danbap's Avatar
ok. i was thinking of the 5.0's.
Quick Reply: Procharger torque specs?
