largest fastest spooling turbo, 364 engine, ptk kit
Masterpower makes good budget turbos, Im told turbonetics of the same wheel size make better power ie a TC76 > MPT76. I know Modular Turbo sells both! Theres also Holset, they make pretty decent turbos as well. Most of us on here run MP, Turbonetics or Borg-Warner turbos though. Greddy makes good stuff, overpriced but good. Im guessing your friend has a DSM,EVO or WRX? lol
On a side note, largest and fastest spooling are opposing ideas. Alot of picking out the right turbo is about what you are running. If youre running a stock ls1 then a t70/t76 will work fine. If you have a fully built 408 then an 88 would be better. You cant really run more than t76 with the PTK kit due to DP size.
motor is ls2(364). forged rods and forged dished pistons(-16cc). dm engine girdle, arp studs. 317's ported(comp valve train), comp cam 224\224 114 lsa, bbk intake(bought for cheap), ported throttle body.
Looking at a turbonetics gtk1000
i am prolly gonna be ordering the god speed kit and running a borg warner 74mm and just cut the t4 flange off and weld a t6 flange on cuz thats what it takes on the BW.. and there cheap and work good, i think the turbo is gonna cost like 550-600... but im also running it on a 408 and if i want bigger i will just swap it out to the 80mm, and gonna make my own downpipe and junk the godspeed one..
I would just do truck manifolds from the start, if I could do it all over again. I think you guys are really underestimating all the bullshit you need to go through to make the ebay kit fit well.....
We (PTE) haven't updated our site in a long time. We are currently working on it. What kind power you looking to make? Our HP76HPS billet comp wheel. It is rated at 1200fwhp (30psi boost) actually makes more power and will spool a little better then our cast 78hps, rated at 1160fwhp.
hope this helps,
Wes
hope this helps,
Wes
hope this helps,
Wes
hope this helps,
Wes
http://www.forcedinductions.com/help.htm
The Borg warner turbos are preety laggy, and then you would have to modify alot of things. Everything about a t6 is larger in comparison to the t4. On this page you can see measurements for the different flanges.
