Thinking about side dump...in the front...
Old 01-28-2010, 12:56 AM
XtremeDime's Avatar
Default Thinking about side dump...in the front...
The downpipe on this ebay kit is pissing me off to no end. Im thinking about dumping my DP off to the side, in front of the driver side wheel. Obviously not facing the tire but with a turn down setup. Im guessing this will be loud as **** but how loud? Is it possible to run some kind of resonator or muffler before it? There will be a bout 10 inches of pipe straight down off the turbo then about 16 inches off to the side. I have an SLP loudmouth muffler that i can probably fit but I dont want to create too much back pressure so Im kind of at a loss on this one. Suggestions?
Old 01-28-2010, 02:11 AM
ninetres's Avatar
Have someone who knows what they are doing (not ching chang meow ebay) fabricate you a downpipe.
Old 01-28-2010, 02:18 AM
TurboAv's Avatar
Right meow?
Old 01-28-2010, 02:25 AM
XtremeDime's Avatar
Its not just the downpipe. Getting one fabricated wont fix anything because Im limited on the space to run it.
Old 01-28-2010, 02:34 AM
stevegrizzle's Avatar
i dont think it will be super loud until you get into boost
Old 01-28-2010, 03:00 AM
XtremeDime's Avatar
Is there a muffler or resonator you would recommend to quiet it down a bit? Im thinking a magnaflow or dynomax
Old 01-28-2010, 04:28 AM
TurboAv's Avatar
Dynomax Bullet. I would run the biggest you can fit. Either 3" inlet/outlet, 3 1/2" inlet/outlet, or 4" inlet/outlet. They are 16.5 overall length, but you can cut them down a couple inches at least by trimming the ends.
Old 01-28-2010, 05:13 AM
KILLER-LS1's Avatar
I have the eBay kit and did EXACTLY what you are asking about. It wasn't that loud compared to my open headers I used to have, but at a red light, my eyes were burning from the fumes. So noise won't be your problem, it will be the smell of the exhaust filling up in the car (poisonous as well) I only had it like that for a few weeks before it pissed me off too much lol
Old 01-28-2010, 05:16 AM
XtremeDime's Avatar
Lol, im gonna try it out on Friday and see if the sound is unbearable or not. If it is, I think i can fit a Borla XS muffler.
Do you have any clips of your car, killer?
Old 01-28-2010, 05:24 AM
KILLER-LS1's Avatar
No. I blew up the stock motor shortly after when my cheap wastegate got stuck. Boosted to like 20psi... It was fun for that minute though
Old 01-28-2010, 10:24 AM
1fast bird's Avatar
That is exactly how I wanted my downpipes routed. My builder decided as short of a run that is, it won't lose enough heat before dumping out. He was afraid of the heat melting the plastic and bubbling paint. I think the rule of thumb is exhaust loses 20 degrees per foot?
The look of the exhaust dumping up front like that is really cool though!!!!
Old 01-28-2010, 11:45 AM
candlelit's Avatar
have you got any pics of underneath your car? I'm wondering if you have any room to dump the exhaust further back under your car...
Old 01-28-2010, 12:05 PM
XtremeDime's Avatar
The only way to dump it further back is going under k member which I will not do lol.
Old 01-28-2010, 12:06 PM
XtremeDime's Avatar
Bwahahah! That sucks man
Old 01-28-2010, 03:08 PM
Tzion_ben_Arthur's Avatar
can you get pic of the under side of the engine area? You may have more room then you think on the drivers side.
Old 01-28-2010, 04:01 PM
XtremeDime's Avatar
Im running an ebay kit, trust me I dont lol. Im also lowered so running under the kmember isnt an option.
Old 01-28-2010, 04:02 PM
71 chevy's Avatar
Schoenfeld sells a straight thru 3 or 3.5 inch muffler in 6 or 9 inch length for $16 and $25
I have the 3" in 6" length and the tone is PERFECTION
It has an aggressive sound but not loud enough to upset neighbors.not even close. It sounds like a stocker with aftermarket mufflers. Compared to my na 454 bbc with flowmasters, this is a lot quieter and mellowe sounding. Ill post a vid and pic later
Old 01-28-2010, 04:05 PM
XtremeDime's Avatar
Awesome! What turbo are you running?
I was also talking to Rob @ Modular, and he said its possible to put a Y-pipe on the DP and run like 2 2" pipes under the k member, which would help out a ton!
Old 01-28-2010, 04:29 PM
MUSTANGBRKR02's Avatar
I fit mine without to many problems.
Old 01-28-2010, 06:19 PM
XtremeDime's Avatar
Mine makes me want to punch babies.
Quick Reply: Thinking about side dump...in the front...
