TC78 Dimensions
Old 01-28-2010, 08:27 PM
Skelbow's Avatar
Default TC78 Dimensions
Could anyone with a TC78 give me some rough dimensions on the size of it?
I have a T4 - 64mm turbo I am using for mock up, just want to know how much more room I need to leave.
with the T4 flange sitting on my table, this 64mm is about 8" tall, 9" from inlet to downpipe flange, and about 9" wide.
Thanks guys.
Old 01-28-2010, 08:32 PM
eviltwin_1987's Avatar
i can get it in like 3hrs if no one else does
Old 01-28-2010, 10:27 PM
kbracing96's Avatar
A TC78 is built in a 60mm compressor cover, so probable right about the same size at the turbo you are using for your mockup. Here is a pic of a TC76 (same size externally) if that helps.
Old 01-29-2010, 12:29 AM
Standing on the flange it is about 7" tall, 8.75" fron end to end, and 9" wide at the Compressor housing with the exit included, about 7.25 without it, and about 6" wide at the exhaust housing not including the flange. That the best I can do with a burning hot turbo, at night, with shakey hands and using this phone as a light. If you need any otherS let me know
Quick Reply: TC78 Dimensions
