Is this cam okay for FI?
This is a custom cam from pat g that was made with the plans for a 100 shot. Also made knowing that 4:10s are in it. Will it be okay for FI? I am changing plans and want to buy a procharger instead of the nitrous route. People use stock cams all the time. I just wanted to make sure if this cam could be used and everything be fine. Kind of a dumb question but you never know.
Cam: 226/232 .609”/.604” 113LSA +2
most cams could be used for everything and work fine.
And it also depends on what sort of FI.
blower, then no reason why that cam wont work just fine. Turbo, perhaps less ideal, but it'll still make good numbers
