ZR1 supercharger on a LS1
Old 02-11-2010, 08:50 AM
Cthulu's Avatar
Default ZR1 supercharger on a LS1
Has anyone fit the ZR1 blower on a LS1 yet?
Check out some pics of it here.
http://detroit.craigslist.org/okl/pts/1579505034.html
Seems cheap. 3300 for a really nice setup, no clue if it's even possible though.
Old 02-11-2010, 09:09 AM
Chris'stransam's Avatar
u need ls3 lsa ls9 or l92 heads 4.0 bore or bigger to fit these heads
Old 02-11-2010, 09:12 AM
ls1plus's Avatar
The new mast small bore l92 heads should work then, correct? Then it could be used on an ls1 i would think.
Old 02-11-2010, 09:24 AM
yepper
Old 02-11-2010, 09:30 AM
ProStreet_632's Avatar
Question is, where did this guy get it from? Not to many of these units around.
Old 02-11-2010, 09:31 AM
JAX04's Avatar
very interesting? Scratches head............. The title says 2200 and the add says 3300??
Old 02-11-2010, 09:47 AM
little bit over 5900.00 for new. with out air to water cooler
Old 02-11-2010, 09:48 AM
OUTLAWZ RACING's Avatar
may be from the new caddie and the poster is posing it as a zr1
Old 02-11-2010, 10:03 AM
JAX04's Avatar
differences?
Old 02-11-2010, 10:15 AM
CAMJAG's Avatar
craigslist post deleted by author
Old 02-11-2010, 11:36 PM
Cthulu's Avatar
Default must
Must have sold already, so you if you L92 heads that will bolt onto a ls1? are you kidding? all the blower lower intake manifold bolts right up to the block?
Old 02-11-2010, 11:40 PM
elias_799's Avatar
^^^ lower intake manifold does not bolt up to the block. it bolts up to the heads
Quick Reply: ZR1 supercharger on a LS1
