Oil Line Restrictor - where to get em'
Old 02-13-2010, 03:36 PM
ZL1Killa's Avatar
Default Oil Line Restrictor - where to get em'
Ok, been trying to find stainless piece (found brass..which would work) however, has anyone been able to locate a stainless 0.065 restrictor fitting??
The line I have to the turbo is a 1/4 OD aircraft braided line with an ID of .160 ; oil pressure feeding the turbo is ~50psi. With the size of that line further pressure drop will occur.... I would figure I would need the 0.065 restrictor or drill it out to 0.096
Here is the brass fitting, and what would be great is if I could find it in STAINLESS as it would screw right in to the top of my turbo, 1/8 NPT
http://www.summitracing.com/parts/ATM-3277/
Old 02-13-2010, 03:40 PM
MUSTANGBRKR02's Avatar
Some people use nitrous jets for this.
Old 02-13-2010, 04:48 PM
XtremeDime's Avatar
Im not using a restrictor at all, running a -3an braided line.
Old 02-13-2010, 05:23 PM
RAACCR's Avatar
We do package consisting of a 1/8" NPT x -4 anodized aluminum fitting, along with your choice of a .065 orifice (for journal bearing turbos) or .040" (for ball bearing turbos). Retail is under $12 for the complete assembly...pm me if you can't find one locally and I could send you one.
Old 02-13-2010, 07:58 PM
RooRnZ28's Avatar
I've been using this one for over a year now and it's been working great.... screws right into the check valve
Old 02-13-2010, 08:41 PM
quicksilverado's Avatar
That is what I use.
Quick Reply: Oil Line Restrictor - where to get em'
