what ring gap?
Old 02-13-2010, 10:43 PM
4SFEDZ's Avatar
Default what ring gap?
385 lt1, 4.04, lookin for 20ish psi! got some hell fires, but not sure bout the gap?
Old 02-14-2010, 04:07 AM
Jontall's Avatar
http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
Old 02-14-2010, 10:00 AM
G Engines's Avatar
IMO .024 on your top ring and .026 on your second.
Old 02-14-2010, 01:47 PM
kdavis's Avatar
Sorry for the tread Jack but I don't want to start a new thread. What gap is good for a 6.0 with twins. Plasma top moly second
Old 02-14-2010, 02:04 PM
4SFEDZ's Avatar
so should your second ring always be a bigger gap? i thought i was suppose to be tighter?
Old 02-14-2010, 08:02 PM
G Engines's Avatar
New tech. in rings recommend that the second ring gap be slightly larger so that it there is any pressure build up between the rings it will escape past the second ring and not lift the top ring land.
I would not run a Plasma molly ring for a FI or nitrous engine you need to have a ductal Iron or steel ring for this.
I have run this .024/.026 gap with as much as 30 Psi of boost with no problems and it would be fine for twin turbos.
Quick Reply: what ring gap?
