Twin Turbo Silverado Build
Old 02-20-2010, 02:14 PM
1_bad94Camaro's Avatar
Default Twin Turbo Silverado Build
Hey guys i'm building a twin turbo Silverado. I'm putting a 6.0 stock bottom end with a 229/229 cam, stock truck heads, and the usual arp bolts. I'll add pics as soon as i take them.
I do have a few questions though. and i'm sure a lot of them have been asked a lot.
first off is what ring gap should I go with on my speed pro plasma rings? I will be pushing 12-13 pounds.
Thanks in advance,
Steven D.
Old 02-20-2010, 02:19 PM
sixt9er's Avatar
^^^Usually, the ring gap info for particular applications comes on a sheet supplied with the pistons/piston rings. I would start there for reference.
What year is your truck?
I have a 2003...looking at "performance options" for it right now...lol!
Old 02-20-2010, 02:45 PM
My truck is a 2000 Z71. I got the motor from an 03 2500HD
Old 02-20-2010, 03:40 PM
eviltwin_1987's Avatar
If you has a stock bottom end, why are you filing rings?
Old 02-20-2010, 03:55 PM
thats a long story. but to make it short my short block had a bent rod and my cylinders had .002 wear in them. the short block also came with another set of rods and pistons. so instead of getting stock rings I thought it would be better to get some oversized rings and file them.
I would have made it a 370 or 408 but I just dont have the funds.
Old 02-20-2010, 04:42 PM
I have another question on the oil ring. when fileing from .30 over how would I file or releve some of the stress on the oiling rings?
Old 02-20-2010, 08:31 PM
Boosted One's Avatar
Are you filing .030"over rings to go in a stock bore?
Old 02-20-2010, 09:28 PM
kdavis's Avatar
yes he is.
Old 02-20-2010, 09:32 PM
cncbird's Avatar
That won't work.
Old 02-21-2010, 01:04 AM
tha joker's Avatar
i know where you can get a complete twin setup for your truck...its a sweet build built by a shop owner for his truck and he makes 800hp with it..if interested pm me
The following users liked this post:
Roger Cam (04-01-2021)
Old 02-21-2010, 10:32 AM
Originally Posted by cncbird
That won't work.
I called Jegs and told them i was looking for some file fit plasma rings. they told me they had file fit plasma rings and gave me the part number so i looked them up with them on the phone and i told them they were .030 over size and they told me yes they were but they could be filed down to fit my application. I already filed one piston. the thing that is kicking my *** is the crinkled ring for oiling. it fits really tight.
Old 02-21-2010, 02:15 PM
The problem will be when you go to install the pistons. Listen carefull for a pop noise when you tighten the ring compressor. That will be one of the rings breaking.
Old 02-21-2010, 02:49 PM
I've got a set of rings done for one piston and everything compresses good. the problem i'm having is the crinkle ring for oil is too tight. Is there any way i can shorten it or take the stress off of it?
Old 02-21-2010, 05:30 PM
jonlisa973's Avatar
sounds like a fun project, post numbers when your done!
Old 02-21-2010, 06:42 PM
will do. i'm aiming for 600 but if i dont hit it I will not be disapointed.
Old 03-27-2010, 08:51 PM
well guys here is an update with pics. by the way i got all the pistons in with the .030 over ring in with out breaking any of the rings so it does work.
Old 03-27-2010, 09:46 PM
Old 03-27-2010, 10:40 PM
kdavis's Avatar
those turbo's were alittle heavier than they look lol
Old 03-27-2010, 11:21 PM
IT_SS's Avatar
what size turbos?
Old 03-27-2010, 11:24 PM
Originally Posted by IT_SS
what size turbos?
57's im wanting a fast spool.
Quick Reply: Twin Turbo Silverado Build
