looking into procharging the 408
I've been looking into prochargers and was thinking of a D1sc. Im would like to stay on 93 octane i would go e85 but the nearest place to get any is 3 hr drive away. im running about 11.34 : 1 compression which i was going to change my heads and cam anyway prolly the epp LS Forced Induction Camshaft and some trickflow heads but if my calculation is right i would be around 10.1 to 10.3 : 1 compression with 70 cc heads ... how much boost could i get away with safely... what do you think i could push out etc.......?
there are lots of variables,but if you get your comp. ratio down to 10 to 1, I dont see you having to much of an issue running around 10lbs. maybe a little more
and of course if you do meth you will be able to get more out of it
im no expert but 10lbs on a 408 should net somewhere between 6-700 rwhp
every setup will be different
an f-series blower would be better on a 408 but it is all about your plans for the car(how much boost,race or street car,etc.)
im sure some of the more experienced guys will chime in soon
I think you will be fine 10.0:1 with 93 and spinning that blower to the max(I doubt you will see more than 10-11 psi on that 408).
yeah 10.1 will be as low as i think i can get it cause i already run i thick gasket .06 .... I really dont now anything on the meth kits trying to find stuff on them. i haven't had my head in the car for awhile been busy and im stationed in korea ... this is a project im trying to plane for when i return home in a few months. do the research so i can just get to work when i get back
With 9.5/1 you can run 16 psi on 93 octane fuel, we have done it quite a few times. If you add methanol injection to it, the inlet air temps will drop 35-40 degrees, and you'll pick up even more power. Bob
Take a look at the power we made on this CTS-V with an F-1A at only 12.5 psi of boost. http://www.eppautomotiveperformance....Car.php?car=29
Bob
Nice ... but what kinda compression you down to ... cause the being 10.1 to 1 i can get mine to is what has me wondering
would have replied sooner but was in the hospital for a week
I think you will be fine 10.0:1 with 93 and spinning that blower to the max(I doubt you will see more than 10-11 psi on that 408). I am running 9.9:1 on my 347 with 13psi on 93 and Meth
