turbos too big?
turbos too big?
i have a built 5.3l lm7 that i'm going to twin turbo. a friend of mine has two of theses turbos for great deal, here are the specs:
Compressor Wheel .70 A/R
Ind: 52.76 mm
Exd: 75.46 mm
Trim: 48.9
Turbiner Wheel .84 A/R
Ind: 57.75 mm
Exd: 73.35 mm
Trim: 61.9
i dont have any mapping on them. what do you guys think?
Ind: 52.76 mm
Exd: 75.46 mm
Trim: 48.9
Ind: 57.75 mm
Exd: 73.35 mm
Trim: 61.9
Ind: 52.76 mm
Exd: 75.46 mm
Trim: 48.9
Ind: 57.75 mm
Exd: 73.35 mm
Trim: 61.9
Ind: 52.76 mm
Exd: 75.46 mm
Trim: 48.9
Ind: 57.75 mm
Exd: 73.35 mm
Trim: 61.9
Max. Rated HP=780
Part No=PT-67
Compressor Wheel Dia.=66.548mm, 84.074mm
Compressor Wheel Trim=63
Compressor A/R Ratio=?
Bearing System=360 Race
Turbine Wheel Dia.=81.28mm
Turbine Wheel Trim=85
Turbine A/R Ratio=.85
My buddy runs these:
Max. Rated HP=1100
Part No=GT42R
Compressor Wheel Dia.=94mm, 102mm
Compressor Wheel Trim=53, 56
Compressor A/R Ratio=0.60
Bearing System=Ball Bearing
Turbine Wheel Dia.=82mm
Turbine Wheel Trim=84
Turbine A/R Ratio=1.15
His is a 7 sec car mine is an 8 sec car.
Max. Rated HP=1100
Part No=GT42R
I can't find the maps for them but I'd guess they'd be a nice fit for your motor. I don't have much experience with motors smaller than 5.7 but I'd think they'd work just fine for you.
