91mm t4 finally home
Old 03-09-2010, 12:21 PM
  #41
Turbo LS1 SS's Avatar
nice, interested in the results! im chasing your record this year looking for 8.5's in a similar built "street" car. i was looking to upgrade to a 91mm as well, but forced inductions no longer does the upgrade on the S88 model.
good luck
Old 03-09-2010, 02:34 PM
  #42
Snyper's Avatar
Originally Posted by DrTurbo
91mm vs 88mm. Apples and oranges.....91 is a bigger wheel and will make more power. Also the comp cover and difuser facing are much larger on the 91. The PT88-47 is an excellent unit for tight spots though where the larger cover 88 and 91 won't fit.
Since space is limited on my nissan would it be worth it next year to when im looking to make more power to upgrade from my pt88 to the pt-88-47?
Old 03-09-2010, 04:14 PM
  #43
MIGHTYMOUSE's Avatar
i think all the questions were answered! thanks!
differences from a shelf tti race-water kit:
-intercooler water tank, hoses, fittings, pump from engien bay to behind drivers seat
-i no longer have an intercooler water radiator (it is not my trans cooler!)
-turbo change from original gt80-r to the pt-88 and now this
-re-made merge pipe for larger exhaust housing to clear water pump, change to 3.5" downpipe flange from 3"
-change from 2.5" to 3" and now 3.5" discharge pipe on the turbo end
-wrapped header at alternator as well as the cross-over piping
-now inlet 90* elbow change from 4x4 to 5x4
-changed from short k&n filter to 12" long cone
-some clamps, couplers and junk like that
Old 03-09-2010, 04:39 PM
  #44
Restricted User
98Z28CobraKiller's Avatar
Missed one. How'd the rod and main bearings look? I'm real curious to know if they are getting beat up at that power level.
Old 03-09-2010, 04:58 PM
  #45
i didnt get them back with the engine, but I was told that they were in good shape considering the miles and use (abuse). the entire rebuild consisted only of rings rod, and main bearings, so that says something there.
the erl ls2 block has some filler in the bottom of it and billet mains (on my stock crank) w/ standard replacement main studs.. thats it far as i know.
Old 03-09-2010, 05:42 PM
  #46
10.5prooutlaw's Avatar
Nice looks good
Old 03-10-2010, 04:20 PM
  #47
Turbo Addict
RICE ETR's Avatar
I guess it's ok......
ok so i have decided it looks pretty sweet...good job...as always
Old 03-10-2010, 06:08 PM
  #48
Jimmy P's Avatar
Looking good. Sorry if I missed it, but what are your new goals as far as power and et with the bigger turbo.
Old 03-10-2010, 09:33 PM
  #49
great question. i don't have an answer. i would like a new best so i'll start there.
Old 03-12-2010, 05:47 PM
  #50
javierb14's Avatar
The elbow is not from a sponsor, I had to look long and hard to find one, and its ribbed on the outside to fight collapsing.
I usually purchase reducing intake elbows over at Air Flow Systems. They have quite a few sizes and decent pricing.
Old 03-13-2010, 05:46 AM
  #51
Restricted User
Is the same stock crank going back in? I forgot that you had a beefier bottom end and 6 bolt heads.
Old 03-13-2010, 09:23 AM
  #52
well i paid $20 for mine not $31 but you are right they have a nice selection.
yep stock crank.
Old 03-13-2010, 10:41 AM
  #53
Sweet71's Avatar
Are you using a pump for the oil drain or just gravity drain?
Cant wait to see that thing go!
Old 03-13-2010, 02:12 PM
  #54
its a gravity drain but i do have some vacuum assist from the pcv system
Old 03-15-2010, 06:38 PM
  #55
CarsandWomen's Avatar
hows that? from the pics it looks like the drain line is horizontal for a good 18 inches. im interested to know how youve got your pcv helping
Old 03-17-2010, 04:12 PM
  #56
read the comment under each picture after you click the links in this thread
https://ls1tech.com/forums/forced-in...ac-system.html
Old 03-04-2013, 02:53 AM
  #57
black-sinner's Avatar
hey i know this is an old thread but how was that 91mm upgrade? did it spool about the same? how much hp did you gain? wasn't the t4 housing chocking the engine up high? what a/r?
i had my pt88 seize up on my new out the box...
Old 03-04-2013, 07:48 AM
  #58
spooled faster than the 88, not sure how much gain. the new owner in texas dyno'd 1060 to the tires thru the 4l80 unlocked yank converter /9"
my pt88 as well as this 91 was no issue from either, sorry to hear it.
here were my last passes prior to selling
Old 03-04-2013, 07:51 AM
  #59
Blackpanther99's Avatar
Looks nice!!
Edit: Running real strong
Old 07-24-2015, 11:45 AM
  #60
Spectre86's Avatar
getting ready to send my 88 in. sorry if I missed it, but what size oil lines did you use?
Quick Reply: 91mm t4 finally home
