radiator for turbo setup
only reason i post here is due to me being turbo so that affect a lot of other item i put on my car, i just purchased a afco dual pass radiator upper inlet has a -16 female bun welded to accept a -20-12 fitting. what size inlet fitting should i go with? what are you guys who are running -AN fitting radiator hoses are you running? thanks
I run a pair of -12s for the upper port(s) its easier that way if you run a remote water pump since the outlets of the meziere block adapters are -12 on either side
