WG piping question
WG piping question
What size should I use? 346, 2.5" hot pipes, tc78, JGS 40mm
My current setup is wrong, I have the WG on the end of a tube that goes toward the flow of exhaust, not away like it is supposed to be. I think I also might have to up the size of the tube as I was seeing a little boost creep. Thanks!
So compared to this one:
https://ls1tech.com/forums/forced-in...rts-non-c.html
having it come straight off should be better right?
Kinda hard to see since I started putting everything back together, but it angles up pretty good, decent amount of clearance from the radiator. Also much much shorter tube. Just need to make a flange and the dump tube. Thanks for the help guys.
