View Poll Results: Is an oil pressure gauge a must?
Yes, explained below.
3
60.00%
No, explained below.
2
40.00%
Voters: 5. You may not vote on this poll
Poll - Oil press gauge?
I'm going turbo. I got a 3 pod pillar and added an AEM tru-boost, an Autometer elec. fuel pressure gauge, and a innovate wideband gauge.
Can the stock oil pressure gauge work, or should I really be running another gauge? The only way I can see it being useful is if it somehow could alarm/alert, or log to HPT.
What do you folks think?
Well folks
Being one of the paramount aspects to monitor on a modified motor, do it. There is no reason (other than to save $80) to not add it. Accuracy is pretty important and IMO no factory gauges are accurate enough. This is one area you wouldn't want to skimp on.
Very true. I use the factory gauge but its better to be safe then sorry. Also it may not be a bad idea to place it near the turbo oil line that way you can make sure its getting good pressure. Just my 2 cents.
An oil pressure gauge isn't really important at all. Especially since they come with a factory gauge. The first gauges I go with are boost, fuel pressure, and exhaust temp. A wideband is needed if you're doing any tuning yourself.
Weird that you mention that, because when I called Precision about the turbo they specifically mentioned NOT putting it inline with the turbo's oil feed... stating that you never want to chance interrupting oil flow to the feed line.
