Intercoolers
Intercoolers
Upgrading to a D1SC from a P1. I have the twin intercoolers that came with the kit. I was wondering since I will be running higher boost in 14 to 15psi range, will they be sufficient or do I need to go with a large front mount?
The twins would be fine with meth even without you'd probably get by. The front mount is great but it robs some boost and you may not want to do that if your trying get as much as possible out of your D1.
