Where to buy 2 bar map>!??!?!
Old 03-16-2010, 01:58 PM
Boost-box's Avatar
Angry Where to buy 2 bar map>!??!?!
Where can i find a 2 bar map, I need AcDelco part # 12615136 or anything that will work in its place. I need the one that plugs into the hole on the back of my LS6 intake manifold and I cant seem to find one ANYWHERE and I dont want to pay $90 freakin bucks at a stealership. Thanks!
Old 03-16-2010, 02:27 PM
Snyper's Avatar
Thats what they go for. You're better off spending an extra 35$ and getting DPEs TRUE 2.5bar(up to 21.5psi) map sensor.
http://www.dpecorvettes.com/gpage4.html
Old 03-16-2010, 04:14 PM
MUSTANGBRKR02's Avatar
pm frost i think he has them for like 65 or something. You are local might even be able to stop by and pick it up.
Old 03-16-2010, 05:26 PM
KOOSWS6's Avatar
I used a map sensor from a chevy cobalt. Not a perfect fit but it does plug into my LS1 wiring harness. Also wouldn't 2.5 bar be something like 36.25psi.
Old 03-16-2010, 05:36 PM
awd-rwd racer's Avatar
go to advanced auto...its a "fdo" factory direct order. im gonna order mine tomorrow. its 51 bucks. which is about the same price ive seen online. at least if something goes wrong i can take it to someone and bitch..that is for the bap (barometric air pressure sensor). its a 2 bar map sensor
Old 03-16-2010, 05:58 PM
eviltwin_1987's Avatar
each bar is like 14.5psi i think. the first bar reads vaccum though
Old 03-16-2010, 08:14 PM
Boost-box's Avatar
The map sensor from an 07 supercharged cobalt is available at advance auto... I only want to push 15-18 pounds of boost and I have heard that the supercharged map is 2.5 bar. Would that be too much?
Old 03-16-2010, 09:11 PM
Snyper's Avatar
1bar is 0psi. 2bar is about 15.
Old 03-17-2010, 03:45 PM
Snyper's Avatar
Its only a 2 bar. The only true plug in direct fit 2.5bar is from dpe corvettes in the link I provided above. Its 125$ and good up to 21.5psi.
Old 03-18-2010, 04:48 PM
Snyper's Avatar
Dont get sensor EC1636 which is what advance will show you. The correct part number is EC1794
Old 10-22-2010, 12:59 PM
sschoeffler's Avatar
He is correct. I just called Oreilly Auto Parts and my price on it is $73.26
Old 10-26-2010, 05:13 PM
Frost's Avatar
You can get it here: http://www.tunedbyfrost.com/products_sens01.htm
Old 10-31-2010, 04:41 AM
Well I just bought my Barometric Pressure Sensor. I spent $56.45 shipped to my house. They have it to you within a week. Its the Cobalt 2.5 bar map sensor. They are not a sponser here so I cant put the link but you can google acdelco 2131631 you will find it.
Old 10-31-2010, 07:03 AM
LS1NOVA's Avatar
You needthe Cobalt baro sensor not the map.
Old 10-31-2010, 09:14 AM
robbyredneck's Avatar
this is kinda old but if you are using hp tuners or efi live you can check for your own piece of mind if you have the right bap sensor. if the scanner pid seems goofy put map volts in the table and look for 2.5v then you'll be sure its the right bap and delete the sae map pid.
Old 10-31-2010, 09:18 AM
Frost's Avatar
Originally Posted by sschoeffler
Well I just bought my MAP sensor. I spent $56.45 shipped to my house. They have it to you within a week. Its the Cobalt 2.5 bar map sensor. They are not a sponser here so I cant put the link but you can google acdelco 2131631 you will find it.
That's the wrong sensor. There is no 2.5bar GenIII OS. The right part number is posted in the very first post (and in my link).
Old 11-01-2010, 12:24 AM
Oops I was wrong on the sensor name, I did get the right sensor tho.
2007 : CHEVROLET : COBALT SS : 2.0L 122 cubic inch L4 FI Supercharged (P) DOHC : Emission : Barometric Pressure Sensor
ACDELCO Part # 2131631 {#12580698, 12615136} replaces 12580698
SENSOR,BARO PRESS $53.79
Quick Reply: Where to buy 2 bar map>!??!?!
