SBC turbo needs help
I want to turbocharge my camaro and I need to know what are the recommended parts that I need,how much C/R is recommended? is forged a must? connecting rod? crankshaft? I got this 383 from my camaro it has flat top pistons with 2 valve relifes from Mahle the connecting rods are I beam and the crank is cast so should I change the pistons to forged nd low compression? I want a street/strip turbo set up and it must be a carburetor I asked someone in youtube about his 406 turbo camaro about tuning it he told me that he use's LM-1 and LMA-3 for tuning so I need your help on this,the transmission is TH350 with shift kit and manual valve body and 3.73 gears the car should weight around 3200-3400
