KY turbo forward facing manifold kit with A/C and power steering
This build is being performed by a shop local to new orleans turbo kit provided by Josh @ Ky turbo. This is a 2002 Camaro 20k miles. We did cam, racetronics fuel system, all UMI suspension, Nitto tires on all four corners and a PTC 3200 stall converter. Keep in mind this is a Daily Driven car.
Restricted User
so is it finished!? looks really good, definately a quality kit. After installing, what did you notice about the kit that you would like to see improved? did you have any problems with the oil plumbing? pics of that would be sweet
good job!
good job!
this was the first kit put out so there were a few things that needed to be fixed this was the R&D kit quality is amazing spark plug change is a bitch as with all manifold turbo kits
we are pulling a coil relocation kit with 90* boots to clear manifolds then the car will pull out i will get pics of the oil feed soon for you with a complete finished job
