New best over the weekend.
I took it out to try the TH400 I just built and installed after 50 miles of driving in town. The track I went to is a 1/4 mile track but they were having issues with water seepage through the joints in the concrete in the traps the day before so they only let us run 1/8th. I only had time to make 4 passes, on the second pass I pulled the wheels a little & on the last pass got a best of 6.59 @ 105 with a 1.47 60' I figured it to be around 10.30ish in the 1/4. I didnt touch any suspension settings either, just 2 step & air pressure in the tires. I figured it did ok considering it had the 6 speed suspension tuneup in it.
On the downside I ran WAY out of injector and fuel pump (racetronix 255 & Siemens 57#ers) but never went lean because I anticipated it and tuned it fat for that reason. One of the benifits of logging fuel pressure I guess.
Anyway here's a vid of the wheelie pass, it also has a pic of the 6.59 slip that I scanned.
http://www.streetfire.net/video/turb...wn_1136436.htm
I'm now gonna shoot for a high 9 with a few more Pounds of boost, new fuel system, & 3.55 gears.
Nice runs looks like you should be getting your 9s for sure. I only hope I can pull off a 9.xx at some point in my car. But may have to go to a few outlaw tracks to do it.
No rollbar and not likely to get one. No rollcage for sure and no crap that NHRA wants for 9s.
I have other car that am going to use for track only car and even that one if it does 9s am going to slow it down!
hey man, I just watched your movie.
Time is doing good, how do you like the TR224? Since I downsized my turbo, i need a new cam so i wont be spinning to 8k anymore lol. Been eyeing the 224 for a while now.
vid wont play for me!?!?!? ugh! good news Hummer, especially since im modeling mine after yours lol.
you 10.70 pass was on a t56 correct?
is that still the stock shortblock with 317's?
just an fyi, FasterProms has 72lbs ls2 flow matched injectors with ls1/6 adapters for like 425+shipping, they just posted a thread about it a few weeks ago.
Thanks, the 4.10's suck for the 1/4. I have the rev limiter set at 6500 and stayed in it on the 6.59 pass till the 1/4 traps and hit the limiter about 20' before the traps. I run a 275 60 15" drag raidial too, which is about a 28" tire, I could have bumped the limiter up a little and made it ok but its just not the right gear for a 3speed turbo car. Now I know why Lenny @ UCC (my converter builder) told me to change to a 3.55 gear before going to the track.
