Finally feeling the power
lol-ran the Chevelle today, wanted to see where i was at on the food chain
best pass was 10.2 @ 131-i jetted up from the dyno tune, just to be sure it was safe-way to rich, so i went back to the jetting on the dyno, still crossed the line with AFR's in the 10.9 range, way to rich-prob could have gotten in the 9's pretty easy, but called it a day, didnt want to push my 4L80E trans, since i built it myself , lol (same with the engine)
i just ran it in street trim, with drag radials, was still spinning some thru the start, poor weight transfer, but its just a street car, so no plans to hammer on the suspension, trying to hook better
D1SC, 403, EPP cam
D1SC, 403, EPP cam
i run a 750 Quickfuel carb that i had Kevin @ CSU setup for me
3.73 gears, use 275/60's on the street, 275 D/R's at the track, car is around 3700 lbs, gotta reweigh it with the
4L80E, def a heavy trans-i had 11 lbs boost under the carb on the dyno
i had my LM-1 hooked up, but at the track i had problems with my laptop
i looked at the runs today on the PC, first pass the AFR's showed in the 9's,
last pass they were in the middle 10's, still way to fat
prob jet it down some more, pull the front sway bar, some other stuff, make a
try for a good 9 sec pass later-with the good weather now, want to keep it in one piece for the cruises, gonna do a 400 mile round trip to OC in May
Nice street car.
