Idler pulley, alternator bracket
I got a ptk ebay kit with a speed inc. alternator relocation bracket. I see the people are using the stock alternator bracket with the idler still in place. I want to know does someone make a single pole stand for the idler so I don't have to cut the alternator bracket. Something similar to the first two pics but a single or double stand with the smooth idler attached?
I have the motor on as stand and everything bolts right up, no problems yet except for a rare wastegate I have. I don't think a turbo that size will fit up front without major modifications. My radiator has already been modified from my old sts setup but I made a fan shroud from sheetmetal and just put two fans on it on my firebird and most likely will do the same depending on how much room I end up with. I will be doing a fmic also
