hows this merge pipe and wastegate location look?
thats how mine is ran. Make sure (if you can) you run the tubing to the wastegate at a 45* off that merge. This will help force exhaust gasses into the wastegate making for accurate and steady boost control. Ive seen a few setups where its welded up 90* and people are wondering why they have boost creep issues..
EDIT, just read where you said you'll have it at a 60* angle. Good game, you did youre homework!!
the shallower (i.e. numerically less) the angle is, the better.
I.E. 60 is better than 90. 45 is better than 60, etc etc etc. You want to exhaust gases to freely flow into it. How you have it pictured will work fine.
