single 14 or dual 12 fans?
no room on the engine side of the of the radiator for fans. so they will be on the front side of the radiator. they will be PUSH fans. i have room for either a single 14" or dual 12" fans. if i had 2 12" fans they edges of the fan will hang over the sides of the end tanks. that would you suggest to get the most cfm and best coling?
this is not my rad and is only for display purposes
thanks
thanks
As someone posted high power fans draw big amps. These draw 23 amps EACH.
See my install below
http://www.summitracing.com/parts/DER-16925/
They're designed to pull air through a radiator only, not push it.
