too much boost???
Old 04-13-2010, 10:25 AM
camaro383's Avatar
Default too much boost???
I am tuning my friends 08 vette with a 416 stroker and vortech t-trim making approx 15psi, and dialing in the wot I had it steady at about 10.5 afr so I took out about 8% fuel and then all of a sudden the next pull its going up to 15:1 afr after a second or two into the pull, the car has tr6's gapped to 35 thousndths, I was gonna throw some tr7s in there, I haven't even pulled the plugs yet but figured I post up for some ideas
Old 04-13-2010, 11:02 AM
ss.slp.ls1's Avatar
What size injectors? Have you checked the duty cycle?
Old 04-13-2010, 11:19 AM
camaro383's Avatar
I have siemens 80lb inje@ctors which are rated at 83lbs at 3 bar fuel pressure so I set the regulator to 43.5, I have a bosch 044 pump in parllel with the stock pump and a hobbs switch for 4psi of boost, and the injector duty cycle seems to be very close btween pulls, I was thinkin that maybe the spark isn't igniting the fuel, and I know when you send raw fuel through it will read lean on the wideband
Btw I also scaled the tables 50% for the injectors
Old 04-13-2010, 04:46 PM
camaro383's Avatar
I put in some br7ef plugs gapped at .030 and I made about I passes and was dialing in the afr and now the same ****, so now I gotta pull the plugs again, anymore ideas lol
Old 04-13-2010, 05:32 PM
camaro383's Avatar
pulled the plugs, and the straps are very white, so im gonna recheck the calibration on the wideband and jump out the extra pump and see what happens, gotta make sure this hobbs switch is working
Old 04-13-2010, 09:32 PM
Restricted User
98Z28CobraKiller's Avatar
You should be running an 8 or colder. Is it still pulling when it goes lean or breaking up? .030 is also kind of a wide gap. I run the 8's at .023.
Old 04-13-2010, 09:57 PM
camaro383's Avatar
I thought 7's would be more than cold enough, and no when the problem happens it just pops and goes way lean, and today when it happened the car barely made it home, but the plugs weren't melted at all, just the straps were very white, like a lean condition..
I was gonna order another set of ngk 7s and run the gap at .26
Old 04-13-2010, 11:16 PM
ss.slp.ls1's Avatar
Are you monitoring the fuel pressure under load?
Old 04-14-2010, 01:03 AM
camaro383's Avatar
Only have a gauge on the regulator so no, but this is happening instantly when I hit wot at about 2k rpm where the stock pump would be able to support the power, like I said though I wanna verify this wideband is reading properly and jump the hobbs switch so I can cancel that out of the picture, and my vacuum/boost line to the regulator is kinda old and dry, so I'm gonna replace that as well, so ill let's u know where I stand tomorrow
Thanks for all the help
Quick Reply: too much boost???
