want to supercharge stock z28
have an 02 z28 and would like to supercharge it just enough to be faster. not looking for 9 sec quarter miles or anything. want to keep it reliable and do it reasonably priced. is there a good kit out there that i can buy to reach my goals? what kind of boost would i run w/ stock motor, and what kind of power numbers look like? thanks
btw... i am clueless to all the acronyms in the stickies, so they mean greek to me.
ben
ben
ben
ben
If you are not in a hurry to buy kit then i would say call or waite for bob at epp..They are going through some changes righ now..I ordered mine from Austin at HPE..Prices are about the same..and any form of power adder is not cheap..
LS1Tech Sponsor
I recommend going with the D-1SC system over the P-1SC system. The D-1SC comes with the wider 8 rib belt assembly, and one inch larger intercoolers. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Ben what kind of power are you looking for? I would highly recommend a top notch set of heads, a good larger(230) cam and good headers, possibly gears. My buddy had an AFR headed 05 GTO and it dynoed 470rwhp.....it was faster than my car was at 4lbs of boost. It will be MUCH cheaper than FI. I have about $13k into my car with a used procharger kit.
Yeah, I'm starting to come to the realization also. FI is not cheap. You can look at theturboforums.com They have some pretty good ways to save money. Still though, it can get expensive.
LS1Tech Sponsor
__________________
Go to the bottom of my thread here..
https://ls1tech.com/forums/forced-in...rbo-setup.html
and read what cobrakiller has done. If I am able to go the turbo route it will be doing something like he has done. Where all the work is done by me. Takes time, but seems to save a ton. Plus when you finish you can say you did it. That may not mean anything to you but it would make me proud.
i would say it all fully depends on your power goals because the supporting mods are roughly the same.
if your shootin for 450ish whp id say do heads cam and maybe some gear and itll feel absolutely nuts theres no question about that and youll probably make more power than the 450 but if its anymore than that id say for the money and to have a laid back type car with a bit more room to grow id say go for the procharger because either way once the power starts gettin up there you have to start worryin about your driveline and especially the bottom end
it all depends on your preferences. and honestly depending on what you have access too ride in or even drive both types of car and they dont necessarily have to be an fbody you just need to have an overall idea of how its gonna be
