View Poll Results: f1 or d1 on camaro ls3
f1 procharger
7
70.00%
d1 procharger
3
30.00%
Voters: 10. You may not vote on this poll
ls3 in 98 camaro f1 or d1
which would you guys go with for alot of street racing and the track on weekneds? going in a 98 camaro 6 speed with ls3 6.2 376!
also would you run the front mount intercoolers or the twin coolers?!?!?!
thanks aj
thanks aj
i would like to forged my motor. but the thing is that its bigger then ls1 and revs higher. the d1sc rating is 62,000 rpms and the f1a is 74,000 rpms.
also i would def be doing a front mount intercooler.
LS1Tech Sponsor
I have seen a 408 with a D-1SC made 16 psi of boost, however, the F-1A is more efficient with you're pushing a D-1SC for all it's worth. It sounds like the D-1SC will do everything you're looking to do, for now. It depends on your future plans. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
7.40 is typically what is needed. Bob
__________________
I had very similar goals, it be easier on parts with a f1a, belt slip would be less of an issue since F series blowers have a 5.40 ratio and it would use a bigger pulley for the same boost.
and since you mentioned street racing, a d1 would be your safest choice if local enforcement is a factor too, cant hide a f1a from the car sitting next to you at a light.
whatever your choice get a good intercooler, so you can drive a lot harder and for longer period of time.
I say f1a, enclosed bypass valve ftw!
