PCV system on 15psi - help.
Old 04-15-2010, 11:59 AM
czwalga00gt's Avatar
Default PCV system on 15psi - help.
Alright, I know this topic has been beaten to death, but it seems the more I read the more confused I get.
I have a ls2, will be running 15 psi. Right now I have nothing hooked up. So open port on each valve cover, 1 intake manifold, 1 TB, 1 valley cover. I also have the back port on the intake hooked up to my brake booster.
Should I cap everything and run the ports on the valve covers to a vented catch can?
Old 04-15-2010, 12:04 PM
Nasty N8's Avatar
Yes a vented catch can is the best way to vent it.
Old 04-15-2010, 12:17 PM
Do you have those in stock? A few questions, does it matter how high it sits in the engine bay, i'd think not but just making sure. (I dont have much room for it so i might have to get creative on where it goes)
Also, to install it, i'd just T the an fitting, run it to each of my valve covers and cap the rest?
Old 04-16-2010, 04:19 AM
Slow5.0.'s Avatar
I just run a breather on both there are baffles in the vc so I've never had a drop of oil come out. I don't know what your refering to on the throttle body
Quick Reply: PCV system on 15psi - help.
