Can flow direction on Mocal oil return pump be changed?
Old 04-16-2010, 06:20 PM
2XR95Z28's Avatar
Default Can flow direction on Mocal oil return pump be changed?
So i'm planning out my rear mount turbo setup on my 5.3 swap s10 and will be having the pump mounted on the frame rail on the passengers side and with it mounted verticle the flow is in the wrong direction...
There is 4 screws holding on the bottom piece that has the fittings in it, i was wondering if i can just take that off and turn it around to make it flow the same way or is there more involved?
Not sure on the p/n, its a brand new pump i got from a friend and the only numbers i can find on it are 804 painted on the back...
Thanks!!
Old 04-17-2010, 07:30 AM
2XR95Z28's Avatar
Bump.... Would like to get this mounted and wired today so any help here?
Old 04-17-2010, 08:41 AM
mcx
mcx's Avatar
i reclocked mine as it was facing the wrong direction...if i rememeber correctly it was alittle more involved but nothing to worry about...its a simple pump with few parts...i paid 55.oo for the rebuild kit and it was maybe 5 parts total??
Old 04-17-2010, 10:03 AM
2XR95Z28's Avatar
Do u know where I could get these parts? Might just end up getting some 180 degree fittings and mount it how it is depending on where I can get the parts and the cost.....
