Valve Float - High RPM breakup
I was just wondering if anyone had an example of what valve float sounds like on an ls1? I think I am getting valve float but not sure because it feels pretty bad and I thought valve float would be more minor.. seems kinda like a bad misfire but only at about 4500 rpms and up.
It is a 98 ss camaro with a 99 firehawk ls1 engine, vortech g-trim on 7psi. Mild cam.. I feel stupid because I didn't even remember to change the valve springs when I put my cam in my new motor..
Doesn't sound any different on my car which currently is floating valves at 5800. Just feels sorta like hitting a wall, so to speak, in the powerband. Loses 80rwhp within the next 500rpms, but never sounds any different.
Ok so maybe it fell out of the tune somehow? Because the car does have a tune for the larger injectors but the gm dealer reset my pcm when I was having problems with it.. I figured the tune was hard flashed..
Might want to close up the gap on the plugs. I had TR6's gapped around .035 and it was blowing out the spark at 10-12 psi over 5k. Switched to NGK br7ef plugs. On heat range colder and gapped to .027. Fixed the spark blowout issue.
Yea im running 7psi.. I just want to know what valve float sounds like because that is the most likely situation right now with boost + cam + stock springs.
If you really think you're floating valves, put your car on a dyno with a wideband and watch the air fuel when you get into the upper RPM band. It will probably dip down into the 10's and you will see a drop in power when you hit that certain RPM and the drop will be pretty substantial.
What are the specs on the mild cam? If this was DanDans motor the springs have almost no miles on them, If the cam is small grab a set of yellow valve springs from a z06 or get some Duals. Are you hearing a rattling sound at higher rpms? If so thats detonation not valve float.
Cam lift won't be as important as cylinder pressure pushing the valves open when you get into the upper rpm band where you make the most boost. You need some springs that are rated at or above 130lbs of open seat pressure.
LS1Tech Sponsor
I'd get the car retuned before you ruin the engine. You should never have a dealer touch the pcm after the car has been tuned. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
