going STS Turbo, need some advice on the set up please.
hey guys i just got an STS Turbo kit for my 2002 WS6 M6, i have never gone forced induction and am lookin for a couple of quick pointers. i am only going 8 PSI max and am keeping the the internals stock. i have the boost controller, tial 38 mm (i think) wastegate, 67mm turbo and all the plumbing, etc... system is non intercooled. also i am going to be running the EPP forced induction cam with it for added performance.
1st, should i get a bigger fuel pump, or something like a kennebell boost a pump, magnavolt??? i have ford green top fuel injectors so i think i might be good on fuel, idk need opinions.
2nd, tuning question, should i get a 2 bar MAP sensor for the car, or can i just lower the MAF threshold to when i start to get in boost??
3rd, anybody have any idea how much power ill be puttin down lmao.
current mods are in sig
thx guys,
Tom
thx guys,
Tom
LS1Tech Sponsor
The 42 lb injectors will be sufficient provided you have enough fuel.
I'd go with a Racetronix Walbro pump in the tank, it is all you need.
I'd keep the stock maf and have it dyno tuned.
I'm going to guess you will be somewhere between 450 and 500 rwhp. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
there are things you need to do to make sure the STS will run ok.
1. the oiling system (if it's a brand new updated system from STS you may not have to worry about it). Be sure to upgrade the oil pump, get rid of the hobbs switch that makes the pump switch between hi and low, and get that....I am having a brain fart right now but it's the piece that starts with an r that is in the oil feed line before the turbo. Oh and don't forget a oil catch can because with FI you need to release crank pressure.
2. Coat and/or wrap your entire exhaust. If you don't do it that's cool but when you decide to you will notice the difference.
3. Look into getting some piping to go under the axle. It will give you less bends in the system.
I may have left some stuff out or used the wrong terms sorry it has been a early morning for me.
thx a ton guys, means a lot, now would it work at all with the stock fuel pump or is that not even a valid question reason i ask is im like broke lol, LTs have to stay on for now for the same reason, but im workin on gettin the exhaust wrap, front mount interkooler, also in the works, i am keepin the cam tho. and Mechanic skills YES, uhh Fab skills...... NO lmao. ill look into it tho, thx for the advise guys, now on the flip side anyone know where i can find a turbo blanket for the 67mm???
I got my turbo blanket from Forcedinductions.com (sponsor). Yes you will need a fuel pump. If you need some money I will take that cam off your hands lol. But until you save up for the fuel pump I would say hold off on the install, you don't want to even chance running lean, better safe than sorry. You may want to check on here for some manifolds I got mine for $25. What are the cam spec's for the one you have in the car now? And what are your goals for this set up it would be easier to steer you in the right direction?
thx for the input guys,
Tom
yes the intake one would be fine for those numbers but when you get the money see about DIY twin intake it's very easy to do and there is a sticky about it. The cam you have isn't too far off from the EPP FI cam it would be interesting to run that to see how it works.
Hmm shorties I think I asked that question before (probably by phone cause I can't remember the answer). Someone should answer this question.
also tuning wise are you guys runnin speed density? if so are you guys runnin it OL or CL when finished tuning?
Zombie wont answer this question... because we have debated this untill we are all sick. The rearmount guys that make real power have all seen this personally... take it as fact. If you want to understand why... do a search for Zombie, 1320, or even me... and look back 1-2 years ago and you can read some very indepth threads that discuss this topic into the thermodynamic level... as well as the actual tests that Zombie and 1320 did...
Or.. save yourself some time and take our word for it... Sell the LT's..
hey since this is a current thread mind if i jump in? i have an 02 z with an sts kit. since i threw a rod bearing and probably blew a piston ring with it im doing a 383 stroker, heads n cam, bigger turbo. i was thinking of going to 9.0-1 for 10-15psi on pump gas. its still a partial dd so i want to keep it acting the same, maybe spool a lil sooner. sound like a good plan? also blacklightning pick up a wideband a/f. if your tuning it yourself get the diablo and work with the guys from sts or just take it to a dyno n its faster. also if you really really want a cam, sts does have a thing with compcams for turbo grinds. but look at a head and cam pack together its just easier
