Procharger questions!
Ok this summer or so i want to do a procharger set up on my car i was wondering Which one could get me to the 800 mark or close to it on pump gas!here is my motor setup also my car is auto!My motor was setup for turbo but wanted to go procharger!
GM 6.0L Iron Block with Stainless Steel O-ringed Deck 370 cubic inches
Lunati Billet Stock Stroke Crankshaft
Callies Billet Main Caps
ARP Main Studs
Lunati Pro Billet Connecting Rods
ARP 2000 Connecting Rod Bolts
Wiseco 8.8:1 Custom Forged Thick Crown Turbo Pistons
Total Seal Piston Ring Set
Rollmaster Heat Treated Double Roller Timing Chain w/Torrington Bearing
Ported Hi Volume oil Pump
Comp Cams 224/ .588" Turbo grind Camshaft
Comp Cams Lifters
Comp Cams Hardened Chromoly Pushrods
ARP 12pt Head Stud Kit
MTI Stage 3 Fully Ported LS6 Cylinder Heads, Stainless Valves, 330+cfm
Jesel Valvetrain 1.7 Roller Rockers
ARP Main Studs
Comp Cams Lifters
I would tend to agree a F1A sounds like a good fit, curious what boost level you will need to support 800 rwhp.
Simple question, why are you planning to use Lunati components? They are great pieces but way overkill for 800 hp. If these pieces are not yet purchased you could save a lot of cash using comp star rods and stock crank.
What are your plans for fuel system? Suspect some upgrades will be needed here too.
LS1Tech Sponsor
I agree in that an F-1A is what I would go with. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
TT-TECH Veteran
F1 or F1 a will do it. Built a 370 with my old F1 did 775 through a 4L80 and he still has to put the smaller pulley on it which will get him about 2-3 more PSI on it if he wants more power. He's pretty happy with it like it is though.
http://www.youtube.com/profile?user=.../0/H4UsRlN_2bI
http://www.youtube.com/profile?user=.../1/agd46J9iJOs
