Results from Dyno Tune
Old 04-21-2010, 08:50 PM
01boydws6's Avatar
Default Results from Dyno Tune
Just wanted to share my results, now at least I know where the car is. I need to add a second fuel pump and re-pulley to get the boost down (stock bottom end)
[IMG][/IMG]
Old 04-22-2010, 01:47 AM
Trans Am Jam's Avatar
care to share the specs on your build for those, like me, who are clueless. impressive dyno sheet though.
Old 04-22-2010, 02:22 AM
stevegrizzle's Avatar
I think youre ok, just need to get the afr dialed in and it should live a while
Old 04-22-2010, 06:48 AM
01boydws6's Avatar
ls6 intake
Tea 1.5 241 heads
60lb injectors
single racetronix pump w/hotwire kit
pace setter lt's
no cats
x-pipe into bassani mufflers dumped
comp 224/224 cam
comp 918 springs
FMIC
D1SC 10.73 lbs of boost
vortech mono valve
6-rib setup with extra idler
ls6 ported oil pump
arp rod bolts
stock crank, rods & pistons
centerforce dual friction clutch
liberty built 6spd
stock 10-bolt with 3.73's
Old 04-24-2010, 09:17 AM
Turbo Addict
RICE ETR's Avatar
Nice numbers...yea I say leave the pully on it :-D
Question for you...did you put the rod bolts in from the bottom so no rebalance?
Old 04-24-2010, 10:06 AM
BLNLS1/RX7's Avatar
Originally Posted by 01boydws6
ls6 intake
Tea 1.5 241 heads
60lb injectors
pace setter lt's
no cats
comp 224/224 cam
comp 918 springs
FMIC
vortech mono valve
ls6 ported oil pump
arp rod bolts
liberty built 6spd
What size block?
Quick Reply: Results from Dyno Tune
